Date/Time: Thu, 24 Sep 2026 12:29:05 +0000
Pago de plataforma
View Count: 683
| [2021-03-30 17:36:28] |
| User691020 - Posts: 10 |
Saludos me pueden enviar por favor la informacion o el linck donde puedo pagar el package 3 de la plataforma.
| [2021-03-30 18:20:48] |
| John - SC Support - Posts: 47994 |
From Google Translate: Greetings, can you please send me the information or the link where I can pay the package 3 of the platform.
Login to your Sierra Chart software and then select Help >> Add Usage Credit. This will log you into the Sierra Chart website using the same Account Name and Password with which you had logged into your Sierra Chart software and will take you to the Payments page. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-31 12:03:09] |
Refer to this thread: Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
