Date/Time: Tue, 25 Feb 2025 01:48:04 +0000
[User Discussion] - BitMEX USD price feed represented in P&L as XBT (Bitcoin) - how to mirror movement in SC
View Count: 573
[2021-03-30 15:35:08] |
User223428 - Posts: 1 |
Am having trouble setting SC to mirror the tick sizes used on BitMEX and was hoping for some guidance. I found article Changing the Price/Value Display Format but there isn't an example I can work back from. How would I mirror this in my SC setup so an order for $1 is reflected accurately against the P&L which moves in XBT? Thanks |
[2021-03-31 03:28:35] |
There is not support for the kind of profit/loss calculation you are looking for.
[2021-03-31 16:38:10] |
ForgivingComputers.com - Posts: 1012 |
I can make a study that does this for you. Sent you a PM Request. Brad Houser |
