Date/Time: Tue, 25 Feb 2025 01:37:31 +0000
[User Discussion] - Modified version of Volume Bar Range Ratio using delta
View Count: 553
[2021-03-30 13:10:56]
User478349 - Posts: 5
Is there anyway to show volume bar range ratio but instead of using volume, use delta (difference between Ask/Bid Volume)?
If there is no preset indicator, is there anyway I can custom build it?
[2021-03-31 03:06:43]
user_xyz - Posts: 446
There are a few ways to do this... I use Studies -> Ask/Bid Vol Diff, then Number Bars Calculated (to display the number of the diff)
