Date/Time: Tue, 25 Feb 2025 01:38:51 +0000
Infinity
View Count: 820
[2021-03-30 03:37:28] |
User152906 - Posts: 8 |
I have an Account with Infinity Futures (TransAct). Can you setup a Trading Account. Thank You in Advance |
[2021-03-30 07:02:03] |
We do not understand the request. A trading account is something that your broker sets up. And we also recommend that you use the Sierra Chart Order Routing Service instead of Transact: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-30 07:04:47
[2021-03-30 13:52:41] |
I use to have an AMP account. I no longer use them. So now when I open a Chartbook it says Server Connection Error Connection error message from service. SC Futures Order Routing/Data|Connection Error Trade account not assigned. |
[2021-03-30 13:56:41] |
I also forgot to mention I will use Sierra Chart Order Routing Service. I also will you the Denali Data Feed. |
[2021-03-30 15:16:26] |
John - SC Support - Posts: 38150 |
AMP stopped support for the Sierra Chart Order Routing Service about a month ago. They should have moved your account to use CQG for order routing with them. If you have not received any information from them, then you would need to check with them. In the meantime, you can follow the instructions in this post to change your setup so you can continue to work with your charts: Removal of TT Trading Accounts from Sierra Chart Accounts for AMP Users If you want to continue to use the Sierra Chart Order Routing Service, then you would need to change brokers. You will find a partial list of brokers that support the service at Step #2 of the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
