Date/Time: Tue, 25 Feb 2025 01:03:52 +0000
Real time Time and Sales shows incorrect.
View Count: 651
[2021-03-30 01:44:22] |
NukazukeL - Posts: 22 |
I use Denali feed. Real time Time and Sales did not show some rows. This issue is not the first time. Charts are correct both real time and replay. Region2 is cumulative volume >= 20. Time and Sales setting is volume >= 20. Replay Time and Sales is correct. |
[2021-03-30 06:53:46] |
Remove all of the filter settings from the Time and Sales window to rule out any of those as an issue. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
