Date/Time: Tue, 25 Feb 2025 01:33:00 +0000
Chart Replay not working
View Count: 727
[2021-03-29 21:11:48]
User203962 - Posts: 9
is there something I should do to fix the replay Chart?
It used to work fine but it is not working anymore
[2021-03-29 21:42:08]
John - SC Support - Posts: 38150
We need more information on what exactly is not working correctly.
[2021-03-29 22:43:28]
On top menu , when you click on chart -> Replay Chart ->Replay Chart(Control panel) or Ctrl-R
It is not giving anything but it is used to give me a small panel where can choose the time to trade
[2021-03-30 14:06:29]
Refer to the following:
Replaying Charts: Chart Replay Window Not Visible
[2021-03-30 20:36:08]
Thanks, that worked
