Date/Time: Tue, 25 Feb 2025 07:25:49 +0000
OneUe Trader - Connection Problem
View Count: 828
[2021-03-29 20:37:35] |
User158665 - Posts: 44 |
I have updated the RIM folder based on this thread: Trial with OneUp Trader But my data keeps connecting and disconnecting all the time. I have sent the Message Log for Analysis. It may be because my Sierra was through AMP, but as we are going to be charged straight by you, I imagine we can solve this, right? What can I do? |
[2021-03-29 21:30:00] |
John - SC Support - Posts: 38150 |
All we can tell you is that there is the following in your Message Log: Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Failed. Result text: "permission denied"
You would need to check with Rithmic on this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-30 01:06:36] |
The Message in DTC Bridge Server: "Listening socket (776). Port 64731 | Closed. Has nothing to do with my Sierra account belonging to AMP? I thought it was, because in 2019 when I tried to use TOPSTEP it did not work with my amp account as well. I had to use my own. |
![]() Attachment Deleted. |
[2021-03-30 14:24:49] |
The limitations on what service you can use your Sierra Chart with are no longer valid. This changed with the change to paying for your Sierra Chart directly to us.
[2021-04-06 01:41:05] |
Is there an update on the Rithmic Bridge? Or this is the latest update? Rithmic Bridge Files |
[2021-04-06 14:18:05] |
That is all there is with regards to the Rithmic Bridge. Rithmic has written a new interface for Sierra Chart and we are starting testing with it. We do not have a timeframe for when this will be available, but the good news is that it is in test. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
