Date/Time: Thu, 01 Oct 2026 22:43:07 +0000
how to access denali data feed
View Count: 816
| [2021-03-29 18:26:57] |
| User570385 - Posts: 4 |
Hi when I click Activate / Deactivate Denali Exchange Data Feed Exchanges [CME / CBOT / NYMEX / COMEX]. That said "The Data Feed is not enabled on the account." I got package 5. how to make the list "to do" green for have access to denali data |
| [2021-03-29 18:58:55] |
| John - SC Support - Posts: 48086 |
From what we are seeing of your account, it looks like you have everything setup now. Let us know if you need further help. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-29 19:02:53] |
yes i got account whit AMP and i put my account on aggreement. how to trade in real whit my account amp on denali data?
| [2021-03-29 19:05:34] |
If you are with AMP, then they should have set you up with CQG for your order routing. As such, you would follow these instructions to connect your Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions Then refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
