Date/Time: Tue, 25 Feb 2025 00:39:46 +0000
Price Overlay - 1min Volume in 10min Candle Chart
View Count: 457
[2021-03-29 17:58:33]
Tobi555 - Posts: 1
I have a 10 minute Candle Bar Chart where I want to draw 10 x 1 minute volume bars for each 10 minute candle bar. So I tried the price overlay study but that did not work as it only shows 1 bar from the source (1 min volume) chart in the (10 min candle stick) target chart. Is this possible with the price overlay study at all or is there another study you suggest to use?
Thank you very much,
Tobias
[2021-03-29 18:42:40]
John - SC Support - Posts: 38150
You would have to do it the other way. Use the Study/Price Overlay to put the 10 minute bar on the 1 minute chart. You will want to ensure that the option for Fill Blanks with Last Value is set to No. Refer to the following:
Study/Price Overlay Study
