Date/Time: Tue, 04 Nov 2025 13:48:48 +0000
Sierra Charts Order Routing Service
View Count: 725
[2021-03-29 16:13:10]
Meklon - Posts: 252
Hello Support, I am in a process of switching my brokers from Infinity to Advantage Futures and I would like to make sure I pick the correct configuration in order to facilitate effective and reliable order routing.
1. Is Sierra Charts Direct Order Routing Service already enabled (including long term order history and risk management)? If not, when is a target date for this service to be available for Sierra Charts customers?
2. If the option 1 (above) is not yet active and available, what do I need to pick for the Order Routing Service with Advantage Futures - Denali Data Feed with TT routing?
Please advise.
Thank you.
[2021-03-29 16:48:28]
You are making a very good decision by moving and getting onto a superior technical solution.
1. Yes this is available now, and currently it is using TT in the background for order routing. So Advantage will set you up with a TT account and assign it to the SierratChartFIX_2 or SierratChartFIX_3 user. There is no cost to the TT account.
2. Not relevant based on the prior answer.
[2021-03-29 16:56:57]
Meklon - Posts: 252
Perfect, thank you Support!
