Date/Time: Tue, 25 Feb 2025 00:58:12 +0000
[User Discussion] - Change from CQG to Denali and Order Routing through Sierra
View Count: 494
[2021-03-29 15:42:51]
User141413 - Posts: 9
Let me apologize in advance if this is, a well ... stupid request for support.
I would like to switch my data feed back to Denali and do away with CQG including order routing.
First, does Sierra having its own order routing services to AMP, my broker? I'm getting conflict information from AMP on this.
Second, could you please direct me to the link to switch from CQG to Denali? I want to do this as seamlessly as possible but I am coming up on a payment to CQG and do not want to be offline trying to get Denali and order routing setup.
Third, there is no third.
Thanks,
[2021-03-29 17:49:40]
John - SC Support - Posts: 38150
AMP is no longer supporting the Sierra Chart Order Routing Service. Therefore, you would need to continue to use CQG for your order routing.
You can use the Denali Exchange Data Feed for your data instead of CQG while using CQG for order routing. Just follow the instructions here to setup the Denali Exchange Data Feed:
