Date/Time: Fri, 25 Sep 2026 09:00:45 +0000
Futures options
View Count: 917
| [2021-03-29 13:00:12] |
| User429954 - Posts: 2 |
I am with AMP and as you probably know they are directing all platform questions here. I am approved for trading futures options but I can't find any information on how to do so. Please direct me to where on the platform I can find the futures options chain and how to place a trade. Also, after I buy a futures option, (/ES), if it is in the money how do I exercise the option and become long, (or short if the case may be), the futures contract? Thanks
| [2021-03-30 07:18:10] |
You are using CQG, so refer to: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#CQGOptionSupportPolicy And refer to: CQG Trading Platform Service: CQG Symbol Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-30 07:18:26
