Date/Time: Tue, 25 Feb 2025 00:38:43 +0000
Interactive Broker Data Feed
View Count: 578
[2021-03-29 11:01:56] |
User78745 - Posts: 38 |
Hi, I am trying to install the Interactive Broker data feed on my Sierra Chat platform but unfortunately when I go to data /trade service settings I have no value related to IB service. Anyone knows how to set up the IB Feed. Just for information I got Sierra Chart directly through Sierra Chart and I also have a date feed with IB. Thank you for your help, regards, |
[2021-03-29 14:10:26] |
You need to set the Global Settings >> Data/Trade Service Settings >> Current Selected Service to Interactive Brokers. Refer to: Settings Windows Interface Specifically to: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-29 15:37:26
[2021-03-29 15:37:31] |
Post above has been updated.
[2021-03-29 17:21:58] |
Hi, Thank you for your prompt reply. Unfortunately, I do not have interactive Brokers already set up. When I go there, Global Settings >> Data/Trade Service Settings >> Current Selected Service, nothing appear (no IB service). Any clue ? regards, |
[2021-03-29 18:26:12] |
John - SC Support - Posts: 38150 |
You just need to click on the right side of that entry where you would expect to have the option for Interactive Brokers. Refer to the following information for how to work with the new windows and that kind of list item in particular: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
