Date/Time: Tue, 25 Feb 2025 01:18:35 +0000
Free trial - using external data
View Count: 567
[2021-03-29 10:06:33] |
eatsleeptrade555 - Posts: 12 |
Hi, I just started my free trial and tried to use rithmic data that I already subcribed as well. I also installed the RIM files. Here;s what I got when I tried http://www.sierrachart.com/image.php?Image=1617012297974.png Thanks |
[2021-03-31 02:34:05] |
We cannot provide any help at this time for Rithmic as it is a service we are not supporting with the current integration but there is new integration coming out in a couple of weeks. Check back then.
