Date/Time: Tue, 25 Feb 2025 04:03:17 +0000
Cumulative delta uptick volume/downtick volume
View Count: 1396
[2021-03-29 09:42:39]
User266447 - Posts: 266
Dear Sir or Madam,
On the bottom of my chart I have a number bars calculated value which includes day cumulative AskV-BidV. If needed please see attachment. Anyway, is it possible to add there cumulative delta uptick volume/downtick volume? It is basically uptick volume - downtick volume cumulated.
If yes, then maybe it is also possible to add bar by bar uptick volume/downtick volume?
I look forward to hearing from you soon.
Kind regards,
Arek
attachmentNumber_Bars.bmp - Attached On 2021-03-29 09:42:12 UTC - Size: 1.15 MB - 352 views
[2021-03-31 20:39:51]
Dear Sir or Madam,
Shall I wait for your support to my above question?
Kind regards,
Arek
[2021-03-31 21:14:55]
John - SC Support - Posts: 38150
The following 3 Subgraphs are already available in the Numbers Bars Calculated Values study:
- Total Up Tick Volume: This displays the Total Up Tick Volume for the bar.
- Total Down Tick Volume: This displays the Total Down Tick Volume for the bar.
- Up/Down Tick Volume Difference: This displays the difference between the Total Up Tick Volume and the Total Down Tick Volume.
If you are looking for something else, then we can't say when we would be able to get to it.
[2021-04-01 10:58:31]
Thank you for your reply.
Is it possible to do 2 things?
1) Build a graph which will be displayed on the bottom of a chart which shows two lines: a) Total Up Tick Volume, b) total Down Tick Volume. I would like to have 2 lines displayed like Stochastic for instance.
2) Based on Up/Down Tick Volume Difference (This displays the difference between the Total Up Tick Volume and the Total Down Tick Volume) have an alert when:
Up tick volume is positive (shows + i.e +1115) and down tick volume has negative number (shows - i.e. -776). And second alert when Up tick volume is negative (i.e. -860) and down tick volume is positive (i.e. +420).
Kind regards,
Arek
[2021-04-01 15:13:22]
1. Yes, just use the Study Subgraph Reference to create a graph of those items. Refer to the following:
2. Refer to the following for how to create alerts:
Study/Chart Alerts And Scanning
