Date/Time: Tue, 25 Feb 2025 00:23:56 +0000
Binance - Slow data download ETH and BTC
View Count: 726
[2021-03-29 09:11:10] |
User623552 - Posts: 69 |
Hi, I've been trying over the past week to use Sierra Chart with the Binance Data feed for ETH and BTC Via SC Data - All services The data download seems to be incredibly slow Taking almost an hour to download a 30min chart with about two months of data I'm used to having many charts up of different timescales, downloading in seconds, for ES, from my regular futures data feed However, Binance seems to be unworkably slow Is this a known problem with Binance, and is there a fix for this? Thanks |
[2021-03-29 13:06:15] |
This is because there is a large amount of data for those symbols and also based on your Internet connection. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
