Date/Time: Fri, 02 Oct 2026 19:19:30 +0000
[User Discussion] - Fibonacci Retracement and Expansion Tool
View Count: 4870
| [2021-03-29 03:24:47] |
| User606770 - Posts: 7 |
Hello, Is it possible to combine the fibonacci retracement and expansion tool into one? IE have the retracement values an the expansion values be drawn at the same time? Thank you, Ed Davey |
| [2021-03-29 03:53:55] |
These are separate drawing tools. They are documented here: Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-07-12 14:17:14] |
| User925138 - Posts: 30 |
Is it possible to add (the Fibonacci Retracement tool) to Sierra charts?
| [2023-07-12 15:40:09] |
| John - SC Support - Posts: 48091 |
The Retracement Tool can be used as a Fibonacci Retracement Tool. You just need to set the Levels as you want them. Refer to the following: Chart Drawing Tools: Price Retracement | Price Expansion | Price Projection Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-08-11 17:16:30] |
Is there an indicator similar to this or can you create one? Thanks, -Kevin Dead Simple Reversal Indicator for ThinkorSwim # Dead Simple Reversal Points # Assembled by BenTen at useThinkScript.com # Converted from https://www.tradingview.com/script/QJ5VgF0D-Simple-Reversal-Point/ # Define Conditions def c1 = close[1] < open[1] and close > open; def c2 = close > open[1]; def c3 = lowest(low, 3) < lowest(low, 50)[1] or lowest(low,3) < lowest(low,50)[2] or lowest(low,3) < lowest(low,50)[3]; def buy = c1 and c2 and c3; def c4 = close[1] > open[1] and close<open; def c5 = close<open[1]; def c6 = highest(high, 3) > highest(high, 50)[1] or highest(high,3) > highest(high,50)[2] or highest(high,3) > highest(high,50)[3]; def sell = c4 and c5 and c6; # Plot Signals plot bullish = buy; bullish.SetPaintingStrategy(PaintingStrategy.BOOLEAN_ARROW_UP); bullish.SetDefaultColor(Color.CYAN); bullish.SetLineWeight(1); plot bearish = sell; bearish.SetPaintingStrategy(PaintingStrategy.BOOLEAN_ARROW_DOWN); bearish.SetDefaultColor(Color.CYAN); bearish.SetLineWeight(1); |
