Date/Time: Wed, 26 Feb 2025 00:12:35 +0000
CQG or Rithmic routing for AMP?
View Count: 2490
[2021-03-28 20:07:20] |
User160234 - Posts: 3 |
I am a new user and have been reading what has been going on with AMP no longer supporting the TT Fix so people have to use CQG order routing instead. I have read many sources, including here, about the various problems with CQG order routing, so I would like to ask if it would be better to use Rithmic order routing instead? I am considering these possible options and would like to know which setup would work best for AMP users of Sierra Chart: 1. CQG order routing with Denali data feed 2. Rithmic order routing and data feed 3. Rithmic order routing with Denali data feed 4. Is there a different optimal setup that AMP users have been using? Thanks! |
[2021-03-29 15:42:25] |
John - SC Support - Posts: 38172 |
At this point, if you are staying with AMP, the best option is to use CQG for order routing (#1). Refer to the following for how to setup your Sierra Chart to connect to CQG: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-29 15:55:02
[2021-04-13 15:18:45] |
The new Rithmic integration is coming soon as well as our order routing service with direct routing to the CME.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-13 15:19:38
[2021-04-18 10:40:53] |
nosast - Posts: 312 |
Rithmic sounds great and at least better than CQG. Could you please make sure, that AMP users can have the same option to choose (Rithmic trading and Denali data) than AMP is currently offering for CQG and Denali? I would go that route until the direct routing to CME is ready for production.
Date Time Of Last Edit: 2021-04-18 17:24:14
[2021-05-04 12:33:15] |
User710133 - Posts: 6 |
Hi Can you please tell me if I do not take up the service when my trial expires tomorrow and I decide to pay for the service in a months time, will all my settings that I have created up to now be saved? Thanks |
[2021-05-04 15:14:04] |
As long as you do not delete your Sierra Chart folder, then all of the settings will be the same as you left them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
