Date/Time: Tue, 25 Feb 2025 00:40:58 +0000
Attached Orders
View Count: 505
[2021-03-28 13:35:26] |
User99275 - Posts: 16 |
Hello, please could you answer to my questions? If I cancel Attached Orders (SL and PT) to Parent order is possible again attached Attached Orders (SL and PT) to Parent order? And what happens with Attached Orders and Parent order if the Sierra Chart is turned off? Thank you |
[2021-03-29 14:08:15] |
Refer to: Attached Orders: Sending Attached Orders Independently And what happens with Attached Orders and Parent order if the Sierra Chart is turned off? How this works is explained here:Attached Orders: General Management of Attached Orders We recommend using the Sierra Chart order routing for the best management of Attached Orders: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
