Date/Time: Tue, 25 Feb 2025 00:18:36 +0000
Open Charbook Group - V 2243 issue
View Count: 496
[2021-03-28 09:14:16]
User877753 - Posts: 152
Looks like "Open Chartbook Group" opens only the fist workbook of the chosen folder with SC 2243.
Downgraded to 2239 : works fine, as it always did.
HTH,
JM
[2021-03-29 14:47:31]
John - SC Support - Posts: 38150
We have just tried this and we are not seeing any issues with V2243. It opens all the Chartbooks that are part of the Chartbook Group when we do this.
We assume that you are referring to a Chartbook when you say the "first workbook of the chosen folder" is opening, meaning that only the first Chartbook is opening. If it is something else, then let us know.
