Date/Time: Tue, 15 Sep 2026 22:29:12 +0000
[User Discussion] - Master Symbol for Futures Contracts?
View Count: 950
[2021-03-27 21:25:17]
user_xyz - Posts: 520
Is there any way to create a 'Master Symbol' for tracking PNL and Stats for futures contracts regardless of exp month, a symbol change or even different accounts so it all rolls up into NQ, ES, CL etc?
If not, could you all add a field under Symbol Settings -> F.US.CLE?## -> (New Field) Master Symbol -> NQ,ES,CL etc, so all contracts associated are 'rolled up' into a consolidated list? Then in Trade Activity Log a new tab [Master Trade Activity] to view the consolidated contracts.
Example YTD just for Crude I already have the following (below). Partly due to multiple brokers/symbols, AMP switch from TT to CQG (symbol change), and probably when your CME Direct Routing goes live yet another symbol change. Even absent all that, I can't see a way to report PNL/Stats for weekly/monthly/yearly, top level contracts like CL or ES.
CL-202101-NYMEX
CL-202102-NYMEX
CL-202103-NYMEX
CL-202104-NYMEX
CL-202105-NYMEX
F.US.CLEF21
F.US.CLEG21
F.US.CLEH21
F.US.CLEJ21
CLF21_FUT_NYMEX
CLG21_FUT_NYMEX
CLH21_FUT_NYMEX
Being able to track all these into a consolidated 'Crude Oil' master symbol would be awesome
Date Time Of Last Edit: 2021-03-28 16:11:24
[2021-03-28 23:48:14]
Why did you all set this to user discussion? I searched through the online manuals and forums and didn't find anything. If it can be done a link would be great, if not I try to offer a suggestion that may work. I can't be the only one that wants a consolidated report of trading activity at the 'top level' of futures contracts...
NOTE: I can see the sheer volume of support requests are really high, CME Direct Routing (massive development effort) and therefore spend even more time than normal searching through forums/manuals working through something before burdening you all.
Date Time Of Last Edit: 2021-03-29 00:11:15
