Date/Time: Tue, 25 Feb 2025 00:43:52 +0000
Datafeed
View Count: 430
[2021-03-27 20:57:39] |
User349564 - Posts: 1 |
I have read the information relating to real-time and delayed datafeed. I am not clear about whether the datafeed I will be getting from Sierra Chart is real-time or delayed. Can you clarify please?
[2021-03-27 22:10:44] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
