Date/Time: Thu, 19 Sep 2024 22:09:33 +0000
stocks cumulative delta and volume by price
View Count: 1328
[2014-03-05 02:40:04] |
bwalks123 - Posts: 122 |
Hi, curious about if I were to link my TD Ameritrade stock account with SierraChart if I would be able to utilize the Volume By Price, Cumulative Delta studies and all the DOM features for stock analysis? Will these studies work with equity data from TD Ameritrade? thx
[2014-03-05 02:42:07] |
Yes. But you will need to stay connected as much as possible to TD Ameritrade to get Bid Volume and Ask Volume: http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#BidVolumeAskVolume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-13 06:28:49] |
darkpool - Posts: 39 |
Hi, Im currently considering TD Ameritrade for my stock trading. I heard from a fellow trader that their historical data is minute data (you have to be connected to receive tick data). Will the Volume by Price study work correctly with the historical minute data (presumably just to a granularity of 1 minute instead of tick)? Thanks. |
[2014-05-13 06:53:43] |
Yes. The Volume by Price study will work with 1 Minute data. The volume per one minute is distributed across the price range of the one minute underlying data.
