Date/Time: Tue, 25 Feb 2025 05:10:17 +0000
Evaluate Package 11
View Count: 795
[2021-03-27 03:26:34] |
User8135477 - Posts: 133 |
I understand there is a function to Evaluate Package 5, but is it possible to keep the data plan (I'm currently on Package 10) and evaluate Package 11 instead?
[2021-03-27 07:28:57] |
We need to look into this and add support for this if this is not already supported.
[2021-03-29 07:29:44] |
Thanks for the response. Please keep me posted, as I'd like to try it out!
[2021-04-05 23:10:12] |
We apologize for the delayed response, yes you would still have access to the data.
Sierra Chart Support |
