Date/Time: Tue, 25 Feb 2025 00:30:04 +0000
Problems with Flex Renko
View Count: 683
[2021-03-27 01:24:07]
Alv P - Posts: 37
Hi ,
I don't understand why the candles (shape) change if you change configuration parameters like :
- Number of days to load
- Session Times
- New bar at session start
- Load or not load weekend data ..
I mean, this should not affect the candlestick formation if it is changed.
I get different candles at the same general settings
Please fix this or tell me what the normal configuration is.
[2021-03-27 07:35:18]
Why not? It definitely will.
Refer to the detailed information here:
Renko Bar Charts
[2021-03-29 12:34:47]
Alv P - Posts: 37
Okay thanks,
And can you explain me why if I have a Flex-renko chart and I duplicate it in the course of the hours the candles are different in relation to the first original chart ?
I have intraday data storage in 1 tick ( global settings )
[2021-03-29 13:07:29]
Refer to step 2 and 3 here:
Working With Charts: Resolving Differences of Chart Bars Between Charts
