Date/Time: Mon, 24 Feb 2025 22:00:50 +0000
ES Cumulative Delta
View Count: 588
[2021-03-26 23:25:03]
WarriorTrader - Posts: 245
I uploaded a 15 minute cumulative delta chart that uses the Denali feed. The cumulative delta does not look right.
Can someone verify this chart by uploading an non-Denali chart so I can compare the data?
http://www.sierrachart.com/image.php?Image=1616799527359.png
Thanks,
WT
[2021-03-27 07:27:04]
That definitely is correct. And it would not make sense there would be any issue with this with the Denali Exchange Data Feed in this regard and comparing to another data feed is not a definite way to verify an issue. The result would likely be just the same.
And this is what we see with IQ Feed:
http://www.sierrachart.com/image.php?Image=1616829826458.png
