Date/Time: Tue, 25 Feb 2025 00:34:45 +0000
Trading Futures
View Count: 488
[2021-03-26 22:09:58]
inusuel - Posts: 10
H i ,
I want to trade futures with sierra chart , ( eurex with data market depth )
I already opend an account in AMP Futures .
What is the better step ?
1- Take sierra chart package 11 in sierra chart + amp future take select " sierra chart denali no data ( routing order only )
or
2-Take sierra chart package 5 in sierra chart + amp future take CQG eurex ?
or
3- another suggestion ?
Thank you
eric st-yves
[2021-03-29 13:45:57]
John - SC Support - Posts: 38150
You will need to use the EUREX data from us. This will be a general requirement coming in May, so best you just start this way.
Therefore, you would need Package 10, 11, or 12, refer to the following for the differences in the packages:
Description of Service Packages and Pricing: Packages
And then go through the process to setup the Denali Exchange Data Feed for EUREX. You will find those instructions here:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX
