Date/Time: Mon, 24 Feb 2025 22:05:33 +0000
Disaffilate
View Count: 611
[2021-03-26 16:00:15] |
Joperman - Posts: 20 |
hello disaffiliate my account and now I can't connect! can you help me connect thanks
[2021-03-26 16:54:45] |
John - SC Support - Posts: 38146 |
Select File >> Data/Trade Service Settings and change the Current Selected Service to SC Data - All Services. Then select Edit >> Translate Symbols to Current Service to update the symbols to the new service setting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-26 21:09:11] |
Refer to: Removal of TT Trading Accounts from Sierra Chart Accounts for AMP Users Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
