Date/Time: Mon, 24 Feb 2025 22:13:24 +0000
Sierra and AMP question
View Count: 599
[2021-03-26 14:24:26] |
User828106 - Posts: 1 |
Good afternoon, I have Sierra Chart 2230 (Tom79Sierra) + Demo and Real account, registered with AMP - Non-Professional Trader. What I need now to try trading Order Flow for a Demo account? Is this possible? Thank you for answer |
[2021-03-26 15:21:34] |
John - SC Support - Posts: 38146 |
Your Sierra Chart account is currently expired, as you have used your free trial time (it ended on March 5, 2021). In order to continue to use Sierra Chart, you will need to funds to your account and select a Service Package. Refer to the following: Sierra Chart Purchase and License Information: Renewing Access In order to use the Order Flow (Numbers Bars) you will need Package 5. If you also want Real-Time data from us, then refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
