Date/Time: Mon, 24 Feb 2025 22:31:48 +0000
AMP futures Sierra direct routing
View Count: 596
[2021-03-26 13:21:37] |
User99934 - Posts: 227 |
Does AMP support the Sierra order routing service? Manager there said I have to use CQG. I don't want to use CQG. They have TT.
[2021-03-26 15:01:31] |
John - SC Support - Posts: 38148 |
AMP is NOT supporting the Sierra Chart Order Routing Service. You would need to use a different broker. Or you could use CQG with AMP. For a partial list of brokers that support the Sierra Chart Order Routing Service, refer to Step #2 of the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
