Date/Time: Fri, 07 Feb 2025 14:45:55 +0000
How to Color Number Bars Based on alert condition
View Count: 605
[2021-03-26 09:10:42] |
User275592 - Posts: 97 |
Hi, I am using Market Depth Historical on a number Bars Chart. The number bars that i use only display green or red color. How can i change the color of the number bars based on alert condition, like Color Bar based on alert condition does for candle sticks (for exemple, based on the slope of a moving average, if positive, numbers bars displayed in grey and purple instead of green and red) ? I tried first to use Color Background on alert condition but Market Depth historical overides it Thank you for your help |
[2021-03-26 14:29:45] |
John - SC Support - Posts: 37808 |
You can not change the color of the Numbers Bars using another tool like the Color Bar Based on Alert Condition. You can only control the colors using the Numbers Bars options. Refer to the following: Numbers Bars: Numbers Bars Background Coloring Methods For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
