Date/Time: Mon, 24 Feb 2025 21:59:28 +0000
Export/Import behavior of Trading Activity Log
View Count: 513
[2021-03-26 01:00:11] |
Tony - Posts: 549 |
Hi, My time zone is UTC + 01:00, I am using custom settings, in purpose of matching the daylight saving schedule in North America. So, if a trade was placed at 15:33:42 local time, for example, that would be 09:33:42 in the morning, Eastern Time. I noticed some bizarre behavior when I did export/import trading logs, as attached .gif file demonstrates, the moment I hit "Export" under File menu, the time in each record reduced by 2 hours, after I saved the exported file and click anywhere in the window, those 2 hours are added back again. This behavior doesn't cause any inconvenience or inaccuracy at this point, because if I clear the log and import the previous exported log, those 2 hours will also be added back. I am just curious what might cause that. Thanks very much Date Time Of Last Edit: 2021-03-26 01:08:01
[2021-03-26 06:36:08] |
This is all well documented: Trade Activity Log: Importing and Exporting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
