Date/Time: Mon, 24 Feb 2025 22:23:34 +0000
TPO and VbP profiles
View Count: 707
[2021-03-25 22:35:17] |
PeterS - Posts: 2 |
I have a chart showing the TPO Daily profile based on 30 min bars along with a volume by price profile study. I would like to add a second Volume by price study that shows the volume only for the current 30 min bar. Adding a second copy of the study and following the instructions in your online documentation generates a profile that is drawn at the right hand edge of the chart window and not just to the right of the existing volume profile for the day. It is possible to achieve my desired arrangement and if so how? Note i have several other studied that place labels on the right hand side of the window which is one reason i cant but the volume profile there. All suggestions welcom |
[2021-03-26 14:08:28] |
John - SC Support - Posts: 38147 |
You can not change the location of the Volume by Price profile that is on the right side. The best option would be to use the Label Column for your labels and put that column on the left hand side of your DOM. Refer to the following: Global Trade Settings Windows: Label Column For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
