Date/Time: Mon, 24 Feb 2025 22:25:56 +0000
Study/Price overlay with custom indicator using tools in ASCIL
View Count: 791
[2021-03-25 21:37:35]
User554446 - Posts: 29
I created a custom indicator that use the rectangle tools to highlight bar of interest on a chart with the NumberChart study. Now I am trying to overlay my rectangles on another chart but it is not working since the price/overlay study doesnt recognize my rectangles created with the tools of ASCIL. How can I create tools that in one chart that can be overlayed on another chart?
Thank you!
[2021-03-25 22:06:59]
John - SC Support - Posts: 38148
Refer to the following:
Using Drawing Tools From an Advanced Custom Study: Adding Chart Drawings to Other Charts from an ACSIL Study Function
[2021-03-26 11:26:53]
If I follow the instruction I can draw on another chart inside the ASCIL using the s_useTool::ChartDrawings. But it not what I was looking for. I want that my script draw on the chart where I attach the study but also can I can use the samme indidcator from another chart using the Study/Price/overlay.
Thank you
[2021-03-26 14:43:17]
You would need to set the drawing as a User Drawn drawing and the copy the drawing to another chartbook. You can not use the Study/Price Overlay, as these are drawings.
Using Drawing Tools From an Advanced Custom Study: s_UseTool::AddAsUserDrawnDrawing
And also to the following:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
[2021-03-26 15:18:59]
I tryed. If I draw manually it works. It doesnt work when I draw with the ASCIL.
Any other idea?
