Date/Time: Mon, 24 Feb 2025 21:57:44 +0000
Extending rectangle with
View Count: 654
[2021-03-25 19:32:28]
User361939 - Posts: 167
Is it possible to draw extending rectangle with vertical line so i while i draw tool i will see where on "Time scale" is this bar. Example at the attachent.
Best Regards
imagerectangle.png / V - Attached On 2021-03-25 19:32:10 UTC - Size: 39.55 KB - 198 views
[2021-03-25 20:42:28]
John - SC Support - Posts: 38146
You can keep the crosshairs on while using tools. Refer to the following:
Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values)
