Date/Time: Tue, 25 Feb 2025 00:26:32 +0000
Compression via
View Count: 714
[2021-03-25 19:18:19] |
User386060 - Posts: 5 |
Hello, I startet compression via "Intraday Data File Management". I want to compress all scid files, but for all files I received a message "No records found to compress" in message log. Selected data unit size was 1 minute. When I open one of these files, I see records with timestamps at 10:06:01, 10:06:05, 10:06:06 and so on. I want to compress all records up to current time. What am I doing wrong? I updated to Version 2239 minutes ago, but the problem still exists. Log-Example: Checking file to compress: P:\SCData\GBL-202103-DTB.SCID | 2021-03-25 18:57:56.611 Not compressing file: No records found to compress | 2021-03-25 18:57:56.623 but the file contains the timestamps from above |
[2021-03-26 00:08:46] |
What do you have Compress Records Older Than set to on the Intraday Data File Management window?
[2021-03-26 14:07:30] |
"Compress Records Older Than" was set to 0. I want to compress all data.
[2021-03-29 15:33:44] |
Sierra_Chart Engineering - Posts: 18554 |
We need some time to look into this.
[2021-03-30 02:30:32] |
Problem is solved for now. I downloaded historical data in 1 Min timeframe. Thank you for support.
