Date/Time: Mon, 24 Feb 2025 22:37:40 +0000
Slow DOM
View Count: 999
[2021-03-25 19:04:31] |
User565974 - Posts: 32 |
Hi Today I tested SC DOM and also compared it with my TT DOM and there is definitely a big difference. While I can see every last quantity traded in TT, SC don´t and also lagging. I changed the Chart intervall to 100ms, it´s faster but still far away from TT. Can you give some advice thanks |
[2021-03-26 00:11:12] |
Refer to: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds Also look at this video: http://videos.sierrachart.com/DenaliDataFeedSpeed_Video_2021-03-22_144752.webm Also when setting the Chart Update Interval, you want to do that specifically on the Trading DOM settings and not the global setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
