Date/Time: Tue, 04 Nov 2025 07:39:41 +0000
Tools
View Count: 813
|   [2021-03-25 18:20:03]     |
| User104714 - Posts: 25 |
                How do you "bring to front" tools like rectangles? For example: When I have certain studies up, like Market Depth Historical Graph, the rectangles get hidden but lines stay on top. Also, how can I have global tools across charts in the same chart book? For example: I want to draw a line on a candlestick chart and have it show up on my numbers bars chart, again, in the same chart book. Thanks! Date Time Of Last Edit: 2021-03-25 18:20:41
|   [2021-03-25 18:53:26]     |
| John - SC Support - Posts: 42737 |
Refer to the following setting and the one after it: Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) how can I have global tools across charts in the same chart book?
Refer to the following for how to copy drawings between charts: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
