Date/Time: Mon, 24 Feb 2025 22:06:27 +0000
Replay Mode no tick by tick marketdata
View Count: 473
[2021-03-25 16:14:06]
User718759 - Posts: 12
Hello, i use the Denali Datafeed with CQG Order Routing Service from AMP.
If i use the Replay Mode from Sierra Chart, the chart dont show me tick by tick data.
In the Numbers Bars Studie the Bid/Ask numbers does not update if the Replay Mode is on.
I only get the new bar if a full minute is dene (in 1 minute chart).
The Cumulative Delta Bars Studie does not show the right Informations.
Thanks.
imageSierra Chart Replay Mode.png / V - Attached On 2021-03-25 16:12:42 UTC - Size: 205.3 KB - 183 views
[2021-03-25 16:21:39]
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
Be sure to also re-download the data fully in the chart following the instructions.
Date Time Of Last Edit: 2021-03-25 16:22:06
[2021-03-26 21:17:49]
The Intraday Data Storage Time Unit is set to 1 Tick already.
I still got no tick by tick data while Replay mode.
I switched the Current Selected Service from "CQG WebAPI (trading)" into "SC Data - All Services (data)"
now i got tick by tick data while replaying historical data.
Why does the CQG WebAPI dont work for replay mode?
Date Time Of Last Edit: 2021-03-26 21:24:07
