Date/Time: Mon, 24 Feb 2025 21:31:38 +0000
dax data
View Count: 837
[2021-03-25 02:59:47] |
Timothy Hartnett - Posts: 5 |
Hi I have been using sierra charts for live market replay on the dax fxcm feed for awhile now. there is normally no problem at all. However now the data does not line up with any other broker data including the cash xetra data. there is about 30 points different and completly different high and lows on charts. I would normally expect a bit of variation between brokers but ive never seen this discrepancy before. It kinda renders it useless to me as I cant replay my normal trading day? What is wrong or what can I do? Thanks. |
[2021-03-25 13:56:59] |
At this time we recommend using the Delayed Exchange Data Feed and getting the true EUREX futures data: Delayed Exchange Data Feed Right now the symbol for the Dax FDAXM21-EUREX You will also need to update to the latest version: Software Download: Fast Update We cannot do anything in regards to that CFD data. It is what it is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-25 13:57:08
