Date/Time: Mon, 24 Feb 2025 21:18:19 +0000
[User Discussion] - Study that shows potential next candle open (for range candles)
View Count: 496
[2021-03-25 01:06:21]
osaga - Posts: 53
Hi SC
Is there a study that will show me the potential open of the next range candle above and below the current candle.
Examples if I am using a 10 tick range candle...
1. Current candle opens and now I see a dot/line/whatever 10 ticks above and below (potentially the next candle will open 10 ticks above or below this open point).
2. If the current candle is 4 ticks high the next candle open indicator will show 6 ticks above or below the current candle.
3. If the current candle is 9 ticks high the next candle open indicator will show 1 tick above or below the current candle. (When the next candle should potentially open).
I think I have described this correctly, if not I will clarify.
Regards
Date Time Of Last Edit: 2021-03-25 01:06:59
[2021-03-25 01:32:25]
cmet - Posts: 648
Studies > Range Bar Predictor
Using your 10 tick example, this will give you and high and low line on the current unfinished bar showing you where price needs to trade to create a new up or down bar.
May not be exactly what you're looking for but sounds similar.
[2021-03-25 11:04:31]
osaga - Posts: 53
Exactly what I was looking for! Thanks so much cmet.
