Date/Time: Mon, 24 Feb 2025 21:25:27 +0000
billing transition for use of sierra chart
View Count: 422
[2021-03-24 23:58:35] |
User481769 - Posts: 1 |
i am trying to set up my sierra billing (from infinity futures/transact) and i am totally confused, i was able to download the current version but i cannot set up a username and password in the accounts section my username wit infinity is (*****) and can u help me |
[2021-03-25 00:07:24] |
There is nothing to set up regarding your username and password. You just log into Sierra Chart as you normally do just like you have in the past. Do you have a problem logging into Sierra Chart?
