Date/Time: Mon, 24 Feb 2025 21:43:15 +0000
[User Discussion] - Building a new computer: Intel vs AMD Recommendations
View Count: 666
[2021-03-24 19:45:04]
rahul - Posts: 167
Hello, I am looking to build a new computer primarily to run Sierra Chart. Hoping you can can provide some inputs.
I was looking at Intel 10900K or AMD 5800x CPU. What do you recommend? I will add 32gb RAM and a NVME SSD.
Also, I am looking run this computer 24/7, so was looking to install Server 2019 (I don't have experience installing this)...so not sure if drivers etc will be an issue. Else I would install Windows 10 and updates only done on Sundays.
I am also looking at recommendations for the following:
1. Remoting into this PC. It should allow to login to the PC remotely after a computer restart if needed.
2. The computer needs to restart itself after power failure i.e. the UPS will shut down the PC. But not sure how to have it boot up when AC power is back.
3. Start Sierra Chart automatically when Windows Starts. If internet is down, it should keep trying to reconnect.
Any help will be highly appreciated. Thank you.
