Date/Time: Mon, 24 Feb 2025 21:51:39 +0000
Version 2239
View Count: 571
[2021-03-24 19:25:14]
Crtfyd - Posts: 281
I just Downloaded Current Version 2239
In my last version to stop charts that Im not using at the moment to relieve the extra computations, I would only load the current days I want in that certain chart. The other charts I have 1 min, Vol, # of Trades, etc, I just set the "Use Date Range" to a future date, then they wouldnt load. This worked fine bc if I had,say, a 10 second chart it wouldnt bogg down my laptop.
In this version all my charts art loading even though I have them set at a future date (Use date Range)! To see if it was just some default thing that didnt catch, I went to each chart, loaded 1 day, "Applied", then switched to a date over a year out (future where this isnt any data yet). Just like before it didnt load anything. So great...I thought. I did this for all of my charts (7), then went back and clicked on the tabs, and they were loaded again, yet the future date was still set. It seems to be loading the current days info, but only from the time that I last reset to a future date, but not the whole current day (today). It obviously wouldnt do this if I was disconnected, but it shouldnt be loading anything since the "Use date Range" is set to a date in the future.
I hope this isnt the new standard bc I have too many different settings and different studies on each chart to simply use a hot key to change, say, 1 min to 5 min. Please clarify.Thank you.
