Date/Time: Tue, 06 Oct 2026 05:15:58 +0000
Shortcut to load specific chart
View Count: 810
[2021-03-24 19:01:55]
User290496 - Posts: 64
Hello-
I am setting up a user-programmable trading keyboard and was wondering if there is a way with the Shortcut functionality built into Sierra to do the following:
I have one chartbook setup with many tabs comprised of various products in different time frames.
Can I assign a hotkey to switch to a particular tab- either opening that chart in the main window or in a new window.
e.g. I would have one button that would open/switch-to a 5min ES chart, another that would open/switch-to a 60min CL chart etc.
Date Time Of Last Edit: 2021-03-24 19:03:04
[2021-03-24 19:39:37]
John - SC Support - Posts: 48114
There are only controls for Previous Chart and Next Chart.
There is also the option for Go To Chart Number, but that opens a window that asks which chart number to go to.
Refer to the following:
Window, CB and CW Menus: Previous Chart (Window)
