Date/Time: Mon, 24 Feb 2025 21:34:16 +0000
Question on IB data
View Count: 551
[2021-03-24 17:56:41] |
User958741 - Posts: 2 |
If I am paying for Denali but have IB listed as my broker for trading purposes am I getting the Denali data feed or the IB data feed? I am mainly looking to use this for setting up a footprint chart so I need decent tick data. Appreciate your time! |
[2021-03-24 19:16:34] |
John - SC Support - Posts: 38146 |
It all depends on the setting for File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds. If this is set to Yes, then you would be getting the Sierra Chart data. If it is set to No, then you would be getting the IB data. Refer to the information at the following link, in particular towards the bottom of the section where it talks about looking for the [M] after the symbol to know if you are getting the data from Sierra Chart or not. Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
