Date/Time: Mon, 25 Nov 2024 18:41:49 +0000
TPO Chart Coloring
View Count: 1336
[2014-03-04 14:30:37]
User16114 - Posts: 153
I would really appreciate a TPO Chart for the ES from 18:00:00 to 17:14:59 with the letters/blocks one solid color from 18:00:00 to 09:29:59 and another solid color from 09:30 to 16:14:59.
I've spent a lot of time trying to achieve this without success.
Is the above possible?
[2014-03-04 17:05:33]
No. This is not supported.
[2014-03-05 02:15:40]
Thinking about this some more, you can achieve this if you have separate profiles for the day and evening sessions. So you will want to use the following Input settings with the study:
New Period At Day Session Start = Yes. Refer to the documentation for the complete instructions to use this input.
TPO Letter/Block Colors = Use Letter/Block Color 1-18 for Periods
Letter/Block Color 1-18 = (use 2 alternating colors)
