Date/Time: Mon, 24 Feb 2025 21:29:52 +0000
Quote Board frozen
View Count: 443
[2021-03-24 16:00:27] |
User876539 - Posts: 1 |
my quote board is frozen and will not update. I have deleted it and reloaded a new one but it will also freeze.
[2021-03-24 16:42:50] |
John - SC Support - Posts: 38146 |
You are not setup to get any Real-Time data from us (Sierra Chart). Are you getting real-time data from CQG?
[2021-03-24 17:51:59] |
Yes you need to contact your broker for help with the CQG data.
