Date/Time: Mon, 24 Feb 2025 21:10:25 +0000
Shortening the Time display to remove micro seconds
View Count: 579
[2021-03-24 14:54:51] |
User593276 - Posts: 1 |
Hi there, My time & sales window shows time to the micro-second and that is bleeding over into price, can I remove some of the digits at the end of the time so its shorter and doesn't run up against the next column, which is the price column. Thank you |
[2021-03-24 15:03:49] |
You can remove both the milliseconds and microseconds portion. On the Time and Sales window, select Settings >> Settings Window and uncheck the option to include Milliseconds and Microseconds.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-24 15:04:21
