Date/Time: Mon, 24 Feb 2025 21:27:24 +0000
small bug in "Study/Price Overlay" - the ShortName of the overlay study is always blan
View Count: 450
[2021-03-24 12:46:54] |
User785302 - Posts: 8 |
Hello SierraChart support, Just thought I let you know about this. It's not a big problem because it defaults to the Name property. Also user can enter shortname manually in the study settings. Case: I have written an ACSIL study where I set both the Name and ShortName for the subgraph. When I use the study it shows the ShortName because it overrides the Name property. When I use the study as an Overlay via "Study/Price Overlay" the ShortName is empty. |
[2021-03-24 14:38:31] |
John - SC Support - Posts: 38146 |
Do you have the option for Always Use Short Names from Source Study set to Yes? If so, then the Short Names for the Subgraphs should be present on the Study/Price Overlay study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-24 15:08:18] |
This solved the problem! Thank you for the quick feedback. I did not even look at the settings of the overlay study before. Thanks again. |
